Residual Water in A/C After Camping
xpatico
Member Posts: 8
Hey All,
I did a search in the archives and came up with nothing. If this has been covered, please point me to the topic.
After camping in the heat and humidity(Florida), system was level and draining properly throughout the night, we towed for about an hour and discovered wet bedding from a/c dripping. Shouldn't this water drain to the exterior? How can I make sure there isn't any residual water sloshing about and getting everything wet? Thanks for your attention. All wise-ass commentary is welcome.
Rob
2015 T@b 320s with high wall mounted Fridgidaire.
Rob
You need to lower the tongue to allow the A/C pan to drain. Here is a recent thread and photos of where the drain is located in the pan.
https://tab-rv.vanillacommunity.com/discussion/comment/140930#Comment_140930
- 917 Introductions
- 404 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
