Running the AC
I bought my TAB 400 Boondock last October but just had the maiden voyage last week. I have some questions about the AC. First, will it start and run when plugged into a regular house outlet (110v)? Also, has anyone installed an Easy Start into the unit so it will start and run while boon docking? Thanks, Greg
  • Denny16
    Denny16 Member Posts: 5,430
    edited July 2020
    Which year model, 2019 or 2020?  Two different ACs were used during this time.
    The Cool Cat, under the front dinette seat, will work on a 2200 watt inverter type generator with or without the soft start.  The Softstart will get you down to 2000 watts generator.  But you would need 400-600 amps of lithium batteries and a 3,000 watt inverter to run the AC of battery power.
  • gregtipton19_
    gregtipton19_ Member Posts: 27
    thanks, Denny
  • AirBoss
    AirBoss Member Posts: 740
    Running on household 110V is no problem. Just need the adapter for the 30amp plug to 110V outlet.
    If you have Elwell Air8 A/C ( under bed) nstead of Coolcat, should still be fine with 2200W genset, depending on what other draw you have.
    San Diego, CA
    www.airbossone.com
  • gregtipton19_
    Thanks, AirBoss!
