The white plastic covers on the utility outlets always kind of stuck out like a sore thumb against the gray background on my 400. I now see the 2021 comes with them painted black and it looks so good! I'm going to call my dealer next week to see if I can order replacement black vents for my fridge vents.
My question is, has anyone painted any of those plastic components? I thought I would order the black parts that are a compatible fit, but there are a few things like the sewer storage cover, cable outlet, outside shower that they dont have a black replacement for (since several things have been moved into the side compartment on the 2021)
I know they make spray paint for plastic, but I'm just thinking it might not last in the elements.
1 ·
Used Krylon Fusion if I remember .......will check .
Painted parts were - Fridge Vents, "T@B", and "320" emblems , AC vent cover , Water fill port, alde vent and outside shower . Everything else was sourced in the color black .
Hindsight ......... thinking I may have been better off painting the Fridge "vents" by the door , grey in color to match the body instead of the black trim . It may have looked better ? Not sure ?
Yes , I used the original holes for reattaching all the painted parts. Used some silicone, and screwed them back on using the original screws.
Here is a more recent picture, after I installed a pitched axle (Boondock) , and new larger tires .
Thanks for the opinion on the black fridge vents . Think I will leave them black , kind of completes the "look" .
Also, just noticed (dont know how I didnt notice this before ! ) that the door catch pieces are still white !
Will have to pull them of and paint them too ! LOL
Also dont forget to squirt a little sealant in the screw holes too .
If I remember , the only things that had sealant / caulk around the perimeters were the a/c vent and the outside shower . Everything else was just screw holes to seal up ....... Although I did go overboard, and made sure everything was well sealed .
