New to RVing, Does it make sense to have a pair of draw bars?
mikedec5to14
mikedec5to14 Member Posts: 6
edited July 2020 in Trailer & Towing
I'm trying to figure out how to configure my hitch.  My tow vehicle is 15 inches tall and my T@B is a 320S, so it is 16 inches.  The videos I've watched seem to say I need a 1" rise in my ball mount.  This seems fine to me if I'm towing the trailer with the tow vehicle empty or nearly empty.  There are certainly times that I will do that (e.g. to get it serviced or when travelling alone),  but when I go out with my wife we will be taking a carload full of accessories (canopy, stove, chairs, etc.) and I expect that the tow vehicle will be sitting somewhat lower.  I thinking that I should get a second ball mount and ball that has a 2" rise.  Like that I can simply switch mounts depending on how full the tow vehicle is.  Does that seem to make sense?
    Welcome to the Forums, and thanks for the funniest headline ever.
  • Mouseketab
    Mouseketab Member Posts: 1,262
    We actually have two draw bars for our T@B for exactly the reasons you stated. Sometimes I need the drop, and sometimes I need a slight rise for when the truck is really loaded.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • dragonsdofly
    @MikeSchwartz, as @lkc001 said, so many ways to respond to this. As long as we're not talking about the big brass kind, yes what you're thinking will work. We have several different drop lengths to accommodate our multiple towing vehicles, and to accommodate family and friends who have or plan to tow the t@b. In your case, flip over a 1" drop to get a 1" upward adjustment. Good luck with this!
  • Denny16
    Denny16 Member Posts: 5,430
    I have several setups for the Jeep Truck, with the top of its receiver a 16.75 inches, for use with the different trailers and wood splitter that I need to tow.
    nice to have the correct setup at hand.
  • lkc001
    lkc001 Member Posts: 881
    welcome Mike!  I knew others would have some good ideas for you😄 that would be more helpful than my comment!  This is a great group & helpful with good ideas & advice
    2018 Tab 400
  • mikedec5to14
    Thank you folks.  Double entendre aside, it was a serious question.  I'll go ahead and invest in the extra ball mount and ball!  Thanks for the info!
  • WilliamA
    WilliamA Member Posts: 154
    If you go to the places I go you'll need at least that many...
    WilliamA
    2021 Jeep Cherokee Trailhawk
    2017 T@G XL
  • VictoriaP
    VictoriaP Member Posts: 1,496
    There is also such a thing as an adjustable ball mount. This is one example: https://smile.amazon.com/MaxxHaul-70067-8-Position-Adjustable-Mount/dp/B008CE06ZA/
  • AirBoss
    AirBoss Member Posts: 740
    I've found one set is more than enough...just sayin'... B)
    San Diego, CA
    www.airbossone.com
  • Horigan
    Horigan Member Posts: 928
    One concern with that type of hitch is that it moves the ball further away from the vehicle hitch receiver, thus increasing the torque on the receiver for a given tongue load.  This hitch has the ball 12.25" out from the hitch pin, when it's usually ~8".  So you'd have to reduce your tongue load accordingly...
    Rich
    2019 T@b 400
    Bellingham WA
  • Denny16
    And it adds more movement from the trailer ball to the receiver.
  • TNOutback
    TNOutback Member Posts: 633
    To answer your question with a straight answer:  yes, I have observed that precise situation and use an adjustable ball mount by B&W for that very reason. I can add an extra inch of height to level out the truck and trailer if I’m loaded up in the truck bed.
  • Tampakayaker
    HAUL-MASTER
    8-In-1 Adjustable Ball Mount Hitch
    A ball mount hitch with adjustable rise and drop
    $32.99
    Tampa FL
  • AirBoss
    Curious. These type of ball mounts do move ball rearward by a few inches or so. What does that do to weight distribution, etc.? Always told to keep the ball as close to the tow vehicle as possible. These mounts do have their advantages...just curious is to what degree they may be offset.
    San Diego, CA
    www.airbossone.com
  • Slackers
    Slackers Member Posts: 490
    We have an adjustable mount. Added a couple of hitch tighteners and it cleaned up nearly all of the movement. Also added a Tekonsha Primus breaker controller and our 320 CSS pulls easily behind our 2019 Ranger. The combo had no issues on a drive thru a twisty 25 mile section of Eastern Kentucky road.
