I just bought a T@B 320 S Boondock Edge. Any suggestions on how to install a second battery in the box? I moved my spare tire onto the rear rack so I can tow with my Outback and now my wet tongue weight is about 180 with a max for the Outback of 200lbs.
0 ·
You might consider just replacing the battery with a Lithium, which gives you the same power as two regular batteries at half the weight.
Only concern will be the suitability of the charging curve if you charge two bridged batteries and one is only 75Ah but the new one is 100Ah. It's not the end of the world if they're not an exact match, but it's generally accepted practice to try and match them if possible, if you're planning to top them off from one charging device.
P.S. Did everyone see that sweet Victron 5000W 100lb pure sine wave beast that Eamon and Bec just put in their van build? Wow!
