I'm wondering if the passenger side sleeping surface could be extended by using one, or both, of the cushions that you need to remove when converting dinette to sleep mode (the ones with the little angle on top).
I've seen pic of the "tall  guy" fix using a small table to extend the head of the bed towards the fridge.  Goal would be to make or use a small table in between bench and fridge, stack one of two of the removed cushions on top, and viola, a continuously level surface where this tall guy could lay his pillow and head.
My questions (since I don't own one yet, but I'm renting one soon)
- what is the height of the seats, floor to top of the wood (no cushion height)?
- what is the cushion height?
- would the removed cushions fit horizontally in between bench and fridge?
Thanks for any measurements or thoughts.
                0 ·
