@Giota And in case you haven't already figured this out, the panel covering the glycol canister is simply secured by 4 keyhole screws...Just slide the panel up about 1/4" and the panel can be pulled out over the screw heads.
2025 T@B 400 Boondock Black Canyon with 400Ah Battle Born and Victron Multiplus 3000 2025 Honda Ridgeline Black Edition with Redarc Trailer Brake Controller
Thank goodness for this forum. Would not have found the glycol tank without you all. And what a surprise to find it there and the hole in the panel for quick referencing. Thank you, @Giota.
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
