So the wireless brake controller was the best option when I bought my new tow vehicle. (I have a tow plug under dash and didnt want to cut that off to hard wire the Tekonsha) Brand new model of the vehicle so no available wiring harness from Tekonsha.   I'm on a trip right now and brakes on trailer applied HARD and was pulling tow vehicle bacj and the blue circle that indicates brake force was all the way around blue. Normally when I apply the brakes it only goes around to about 2-3pm position. I dropped the setting down to 2 and the brakes are no longer pulling hard but the blue circle is still going all the way around on the app. I reinstalled the app. Didnt fix it.  If I just raise the power to the next level, 7, I feel it pulling a bit to much.  Before today my setting was 17 and it's been fine for a year and a half.
Anyone have any ideas why this might he happening? Im nervous now about my trip home. I'm going to see now if the wiring harness for the Tekonsha one is now available for my vehicle. I was never comfortable with this one but it was working fine!
Help please!
                0 ·
I will be watching your answers also. Have you tried setting up a new profile on the same vehicle ? You may be calling the Mfg. if it follows
2019 T@B 320 S
I will try adding a new profile tomorrow. Good idea. I'm nervous about my trip home tomorrow, but only 60 miles. I will take it slow with LOTS of following distance.
Don't worry too much about it. Even with no trailer brakes, the T@B isn't such a big trailer that you'll feel out of control in any way. And 60 miles is really nothing in terms of towing.
Good luck with sorting out the issue, but I'm certain you'll be okay getting home.
Max Power 17 and sensitivity 2 and when I applied the brakes the blue intensity ring (like I said before would go to about the 3pm position) When I got going this past Saturday I was on my usual 17/2 but now when I applied brakes circle went all the way around, but brakes were not grabbing at all...at first. So after brakes heated up (about 20 miles) and I encountered traffic they beared down WAY too much...so I backed it down to 12, still grabbing, then 2 in order to reach my destination. So, I get up this morning, hooked up, and now my available settings are only showing in increments of 5! Lowest setting, 5, 10, 15, 20! So, I tested around the area at 15 and seemed perfect, stopped few miles later, a bit too much so backed down to 10....good for about the next 45 miles (no traffic) THEN, hit another patch of traffic and 10 was WAY to much again! So backed it down to 5 and was fine. So, I think has to be a major app update since I could no longer even select 2, 12. 17 and onky had options 5, 10, 15. I'm also thinking maybe the blue intensity ring also now just goes all the way around on all settings....I'm calling Curt first thing tomorrow....but new Tekonsha P3 arriving Thursday (they finally got OEM wire harness specific to my vehicle). I was never comfortable with the wireless Echo even though it worked very well for a year and a half. I will repost what I find out tomorrow from Curt.
I was able to get hold of a different Echo and it works correctly.
What I've noticed though is that after I've done the initial setup, the green LED on the Echo does not come on at all unless the trailer is plugged in. I'm confused by the comment above about plugging the Echo in and letting it sync for a few seconds. In my case, there's no lights and no activity at all either with the LED or the app on an iphone no matter how long I wait - until I plug in the trailer.
I'm curious what others have experienced. While I like the Echo when it works, I'm finding it a bit erratic in how it behaves.
When I first ran into the 100% brake application problem, I wanted to reset everything, erase the app, and start over. I could do that with the App but the Echo itself seemed to be behaving differently (no LED on) and of course, there doesn't seem to be a 'reset to factory-new settings' option.
In your case, no lights is definitely not right.
Whoda Thunk it...
2019 T@B 320 S
Below is a picture of the Echo (left) and the T@B female connector (right). Note that the Echo only has a solid blade on the outside of the slot and no spring tension. That means that all the contact tension has to come from the Tow Vehicle side. The Toyota connector is a J with the short leg to the outside. I had to go in and carefully flex the short side of the J outward to make solid contact with the copper blade of the Echo.
The T@B connector on the other hand is a forked slot where it supplies tension as well to the connection. I won't say that the Echo connector is 'bad' but the T@B certainly seems to be a 'better' connector.
While talking to the Rep, he reiterated the following as 'good practice to follow' with each use:
1) Start the TV and plug in the Echo without the trailer - you should see the blue blinking LED, then the Blue solid LED once it syncs with the phone app.
2) Set the Power and Sensitivity to 85% and 6. He recommended these settings regardless. I haven't towed with them yet but he implied that if the Echo has been properly initialized in step 1), it will be a good solution and still leave lots of extra braking capability for a panic stop.
3) Plug in the T@B, the LED should fast blink yellow (calibration phase), then end up at solid green - ready to tow.
So - if you seem to have erratic T@B brake behaviour, perhaps this can help. I spent a lot of time exploring the whole path from the TV battery and fuses back to the T@B and it wasn't until the rep confirmed that I absolutely had to see the Blue LED come on without the trailer connected, that I followed the path of the 12V aux Voltage and the lack of connector contact since that's what powers the Echo. How it was working without it, I can't tell you but I suspect it was getting some voltage from the battery of the T@B but insufficient for proper function. I know that I'll be using his method of connection outlined above as that provides good visual feedback that the Echo gets initialized correctly.
2019 T@B 320 S
I also 'by accident' one time I didn't follow the sequence on plugging in things that are stated above. I just plugged in the controller to the TV, plugged in the trailer, then synced the app with bluetooth. Before even moving, I stepped on the brake and the blue circle went around to the 5 o'clock position (normally it would be 1 o'clock).
I stopped right there, unplugged everything, reattached it using the correct order and all was good.
i haven’t decided if I’ll keep it for possible use on other vehicles or sell it (at a great price if any one is interested). Possibly with the updated app and more attention to detail, it will work out fine for someone else. I use 65 and 5 as the settings on my Ridgeline - Tab 400 setup, works great when it works!
Poughquag, NY
I too am considering going to a hardwired controller. In my case, I have one more reason - the location of the Toyota 4Runner 7 pin tow vehicle plug is far to the left and at a 45 degree angle down - that doesn't lend itself well to the extended length of the Echo either. Best of luck with your next controller.
It is an expensive add on, I got a little frustrated at first, but I looked at my End Of Day process as I made a lot of miles and stops and a whole lot of self education.
16 Days of start and stop travel.
I think most of my odd problems were induced by my own daily shutdowns.
I noticed a few hard stops at the beginning of our day.
Looking back and considering the comments on the echo, I noticed that I had battery trailer power or TV trailer power usually on the Curt overnight. I assumed any issues I had were due to inconsistent power removal. I think I may have confused it more than anything.
out of confusion, I got in the habit of selecting my profile in a 2 step sequence after being down for the night. One I don't use and then I set the one that I prefer to use. Kind of a 2 tap reset . It did not take more than 30 seconds on average and seemed to go without incident.
Either way the daily start and go sequence seemed to work for me after that. I think I just needed to completely disconnect for the night.
In all honestly, I love it. If I had a wish - I would find a way to attach it a little more securely and a lot more discreetly.
If it helps anyone to know my experience, I am glad, if not I at least shared my trip issues.
All be safe and try to wear the tread off
2019 T@B 320 S
