Hi all,
Just curious as I continue to learn the rig ... do you open all 4 valves to drain the fresh water in between trips?
a) & b) the 2 hot and cold low point valves in the Nautilus P2.5
c) Fresh water drain valve just behind the passenger's side rear
d) Yellow Alde drain valve underneath the driver's side cushion?
Also, do you operate the pump at all to accelerate the draining? Is it safe to do so?
                2021 Tab 320 S Boondock | 2021 Ram 1500
0 ·
