Ideas for where to put dog water bowl?
rhyno
Member Posts: 393
We will be camping with our 3 dogs (Bambi, Millie and Bug) when we get our Tab 400 next spring. When we had a 34ft Rockwood Windjammer, there was plenty of room for water and food bowls inside. We would like to figure out where to put at least one water bowl inside for our 2 older pups. I was thinking of putting a bowl in the cubbie below the wardrobe then maybe put a little shelf above the bowl to be able to still use that space for some storage. Any ideas?
I bought one of the silicone two dog bowl holders, added one water bowl to it, and I placed it straight across from the door. That ended up being a place that I never seemed to step and it rarely spilled. Of course, this was for one dog and not three. I also placed her food bowl in the silicone holder, too.Verna, Columbus, IN
We have food and water under dinette, still kick it once in a while and then we empty prior to travel. There really isn't a good permanent location in such a small trailer.2019 T@B 400 Boondock Lite0
The under wardrobe cubby on 2021 TaB400 would work for small dogs.
I would just put it wherever the dogs tell you they want it!Dan and Liz 2019 TAB 400 BDL 2010 Toyota Tacoma V6 4WD TRD Sport1
How about a version of this mod --
https://tab-rv.vanillacommunity.com/discussion/7655/cat-door-to-wet-bath-in-t-b-400
Plus a couple of these (one for the wetbath; another outside) --
https://www.amazon.com/Petmate-Replendish-Gravity-Microban-Dispenser/dp/B0057LAH6O
2015 T@B Max S (White/Silver) -> 2014 Ford Escape 2.0L (turbo, AWD, factory tow)0 -
We are going to prop open the wet bath door then we are away, then who knows the dogs may tell us they want a drink of water. One will immediately, the other? At least you won't kick it over until you got to the restroom.. and it has a floor drain.Former 5th wheel and now T@B 320s owner. Amateur Radio Operator. Pulled by 2019 Ford Ranger Lariat 4 x 40
