We constantly have to loosen the lower screw on the door latch so it closes and opens smoothly. It seems like that screw gets turned and tightened every time the door is opened and closed requiring regular adjustment. We’re afraid if we don’t stay on top of it we could get locked out at some point. Any maintenance or fix suggestions.
0 ·
It is sold in red and blue. RED (maximum strength) is more permanent, while the BLUE (low strength) is less permanent.
YOU WANT THE BLUE VERSION - - it will secure a loose screw, but still allow you to remove the screw later, if necessary.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
