How to set jwm6a clock?
Using the factory directions is no help in actually setting the clock. Does anyone know the trick?
  • dragonsdofly
    @Tchrdude, welcome to the forum. What model t@b do you have? That info will make it much easier for someone accurately answer your question. Someone who has the same model and has done what you are asking.
  • Tchrdude
    Tchrdude Member Posts: 6
    2016 CS-S Max ( I did put down the model number of the radio so that anyone with that model radio, regardless of their trailer, could answer).
  • MichiganSunshine
    MichiganSunshine Member Posts: 19
    @Tchrdude. This post is old (1 1/2 years later) but I will leave the answer for someone searching (like me)
    Hold down the mode/display button for a couple of seconds.  Then hold down the Alarm set button until the numbers start to flash. Then use the << and >> buttons for hour and minutes
    Kathy - Lansing, MI
    2017 T@B 320 SC-S, 2016 Suburu Outback
  • JP2558
    JP2558 Member Posts: 248
    When the time is set per MichiganSunshine, the last step is to press ENTER SEARCH to save the new time and exit the clock setting mode.
    Thanks, Jerry
