How to set jwm6a clock?
Tchrdude
Member Posts: 6
Using the factory directions is no help in actually setting the clock. Does anyone know the trick?
@Tchrdude, welcome to the forum. What model t@b do you have? That info will make it much easier for someone accurately answer your question. Someone who has the same model and has done what you are asking.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
2016 CS-S Max ( I did put down the model number of the radio so that anyone with that model radio, regardless of their trailer, could answer).0
@Tchrdude. This post is old (1 1/2 years later) but I will leave the answer for someone searching (like me)
Hold down the mode/display button for a couple of seconds. Then hold down the Alarm set button until the numbers start to flash. Then use the << and >> buttons for hour and minutesKathy - Lansing, MI
2017 T@B 320 SC-S, 2016 Suburu Outback0 -
When the time is set per MichiganSunshine, the last step is to press ENTER SEARCH to save the new time and exit the clock setting mode.
Thanks, Jerry
2019 Honda Pilot AWD and 2018 T@B 320-CS hanging out on the left edge of Lake Erie.0
