Alde Hot water icon
Hi All, on my 2021 320S BD, is it normal for the ALDE hot water heater icon (the triangular bar next to the shower head icon) to go empty/blank after some time when the water has come to temperature?
To me, when going into the Menu and hitting the “+” on the shower Icon, the triangular bar fills in But when I return to the menu, it goes back to being blanked out.
The bar below it stays filled in as 2KW.
When does that shower head bar fill back in?
2021 Tab 320 S Boondock | 2021 Ram 1500
    Check to see if the Alde is set to Thermo instead of Continuous.  A screenshot may help us help you😊
  • JabGopher
    JabGopher Member Posts: 63
    A hah it was set to Continuous.
    Ah ha!  That seems to be a theme with the 2021s.
