Thoughts on keyless unit for TAB 400
Mariah400
Member Posts: 3
RVLock V4 Keyless Entry Handle w/Integrated Keypad & Fob https://www.amazon.com/dp/B00N58KQMQ/ref=cm_sw_r_cp_api_i_4j4xFbS8X53RT
Appreciate prod and cons fellow adventurers.
My understanding is that RVLock doesn’t currently make a keyless unit that fits either the 400, or the 2020-2021 320 doors.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW -
@Mariah400 There's the fit guide. I guess you could call them up.
https://www.rvlock.com/pages/fit-guide
2019 Tacoma Off Road
2014 T@B S Wet Bath Max Plus
Whenever you find yourself on the side of the majority, it is time to reform (or pause and reflect).
-Mark Twain -
Your 2014 has a completely different kind of door and lock than the OP’s 400. The RVlock does not fit the Tab doors that have built in storage. The good news, those newer doors also aren’t all keyed alike the way the older doors are.Finchy said:@Mariah400 There's the fit guide. I guess you could call them up.
https://www.rvlock.com/pages/fit-guide2019 320s BD Lite, white with blue (“Haven”)
- 917 Introductions
- 73 Teardrop Groups & Links
