Tv antenna connections
TxNew23ers
Member Posts: 17
I have a tab 320 and the antenna connects inside the nautilus compartment- my question is what port do I use, Cable, Aux, or Sat? I’ve tried all three and done a scan for stations but still not getting anything.
TV set to "Air", of course. My guess would be the "cable" connector.Some people have discovered the connector on the back of the TV itself was not connected or loose.
Towed by 2014 Touareg TDi -
If I remember correct from a video of this setup, only the Cable connection is being used by the TaB, the other two are not connected to anything on the back of the Nautilus panel.Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
On my 2021 320S, I hooked a temporary, 'home-made' antenna up to the 'cable' connection on the Nautilus panel. In town (15 miles south of Detroit), I picked up 38 channels!. I purchased an inside/outside antenna from Amazon and picked up only 14. I sent that one back!
@Basil48192 . I have a "leaf" antenna, and it doesn't seem to be getting any channels when I do a channel scan on "air" setting on the TV.
- 916 Introductions
- 72 Teardrop Groups & Links
