Wall coverings
Anyone had the wall fabric recovered? Thinking it would be fun to have the fabric by dinette reupholstered with something a little more exciting than grey. We have the 400 BD, looks like the fabric panels would just pop out fairly easily. Thoughts or advice if you have done this?
  • vhollowvhollow Member Posts: 92
    I have not done this but I have removed the cloth-covered interior panels. The round snap covers may be pried off with a putty knife or flat bladed screw driver. Underneath are snap-screws. Be careful screwing them in with your new fabric, as the wall skin is quite thin and it is easy to strip the threads with the screws.
  • VictoriousJaneVictoriousJane Member Posts: 22
    Okay, great tip, thank you! Did you just leave the walls bare? I didnt even think about not having the fabric panels up!
    No, I replaced a panel after repairs. My back (over bed) driver-side panel vibrated loose, partially detaching and stripping the screw-hole threads in one corner. I sealed the damaged holes with JB Weld (epoxy resin putty), re-drilled them, with a smaller diameter hole, then replaced the panel and screws.
