120 VAC receptacle on T@B320
Any one know the Amps rating for 120 VAC receptacle on top of the T@B 320's sink? I want to put a standard Kcup Coffee machine there and wonder what is the rating of this 120VAC's receptacle?
Thanks for all comments
    MuttonChops Member Posts: 2,069
    Most T@B 320S have the Sink outlet on the same 15 Amp Breaker as the outlet beside
    the WFCO Power Center.
    @huanvanho ;
    Recommend you check-out the Users manuals & Resources section of this forum. [ link on left side of forum page]
  • GatorEgg
    GatorEgg Member Posts: 482
    We use the small cup inside and out. With no problems.  Also had the “bug zapper” plugged in with the kcup outside.
    Odessa, Fl.
  • Tampakayaker
    We've used our K-Cup there with no issues.
    And we've used a Ninja Foodi grill on the outside outlet.  It's 1760 watts and 12 amps with no problems.
    Tampa FL
    ScottG Administrator Posts: 5,693
    +1 what MuttonChops said. The amperage of a receptacle is limited by the breaker or fuse protecting its circuit (which in turn depends on the gauge of the wire in that circuit). In this case that circuit is limited to 15A.
    Keep in mind that with multiple receptacles on one circuit, if you are running something else in another location, you may not have the full 15A to work with. Regardless, the worst that will happen is you will trip the breaker.
  • huanvanho
    huanvanho Member Posts: 48
    Very good information. Thank you Mutton.
  • Dalehelman
    The breaker that controls the outlet in question will tell you what the Circuit is rated for.
    1. Hash  T@B Fun
