Does the new 2021 Jensen cube stereo play audio from the television when you're watching over an antenna or cable? I don't see HDMI ARC mentioned in the Jensen Cube's user manual. Does it work via the RCA aux inputs maybe?
0 ·
The Jensen TV does support ARC...and there is an HDMI cable connected between the TV and Cube - so it might work.
Having just looked at the TV...it does also have RCA stereo audio out...so it must play over the Cube for Antenna and Cable. Guessing that's what the Aux input setting is for on the Cube...
I then set the Jensen to AUX mode.
The TV was then able to successfully scan for channels.
I was able to watch over the air stations on the TV and listen to the sound through the T@B front and rear speakers.
Is that the functionality that you wanted to be verified?
2019 Jeep Grand Cherokee Overland V6
Cincinnati, OH
