I have 2016 TAB 320-S and a 2020 Subaru Outback XT. My mechanic is adding the wiring to the TV to make it a 7-pin harness. He wants to know what amperage does the trailer need from the TV while the TV is running. I know the trailer battery needs to charge (and perhaps run the 12v fridge) while driving. I also have electric brakes on the trailer. (However, I'm not sure if brake electrical use is included in this wiring.) The mechanic is adding the wire to charge the trailer battery and doesn't know the fuse size needed between the car and trailer. He is adding a wired brake controller, too. Can you help?
2024 T@B 320 S, 2023 Toyota Highlander Hybrid LE
