Stabilizer jack lube
I was using WD-40 on the stabilizer screws on my old T@B 320 S but always wondered if there was a better way. I could use a grease but is there a downside to that, with picking up all sorts of road crud?
Now that I've traded up to a 400, what else might I use?
Thanks, all.
  • RCB
    RCB Member Posts: 251
    I’ve wondered as well. There is a chain lube for bicycles that might work. Bike chains are subject to a of mud and grit. I recall it is wax based.
    400 - 2019
    St Catharines, ON
  • tabiphile
    tabiphile Member Posts: 472
    You might be better off using actual lubricant. Tri-flow is a good one...it cleans and protects against rust and contains PTFE. There are many others to choose from...spray graphite will not offer the rust protection but it will not collect dirt. Silicon spray is also a better option and you should probably have it around for spraying the hitch/ball.
  • falcon1970
    falcon1970 Member Posts: 758
    Boeshield T-9!  It won't collect dust and dirt like WD-40 and is wax based.  The downside is that it is pricy.
  • mreric
    mreric Member Posts: 154
    since i own a motorcycle is use motorcycle chain lube on them,
  • Tampakayaker
    I used an RV Slide lubricant that worked really good.  It was a dry type spray silicone that dried to a white powder.
    Tampa FL
  • tabiphile
    Yes...White Lightning. Great stuff but it would not be very easy to apply and it's pricey. Works great on cycles though.
  • rcuomo
    rcuomo Member Posts: 321
    Ditto Falcon 1970- Boeshield T-9 is perfect for jackscrews (was developed by Boeing specifically for that use), also for hitch coupling and pretty much everything that needs lubrication and corrosion protection.
    Huntington LI
  • Marco
    Marco Member Posts: 18
    I used leftover grease when I changed the axle/wheel grease. It works fine
  • DenisP
    DenisP Member Posts: 542
    I also have used Boeshield T-9 for stabilizers and for Ultimate tongue jack lubrication and it has worked really well. It seems to last longer than lithium grease I had previously used and is less messy.
    2013 Tundra TRD 5.7L
    Massachusetts
  • ChanW
    ChanW Member Posts: 3,165
    Note the Boeshield T-9 comes in a small 'drip' type bottle besides the spray bottle. They sell it for bicycle chain lube.
    I think it's much easier to deal with without waste.
