Help! water leak under the front driver side of my 2017 320S. I noticed the leak after I put water in fresh tank and turn on the faucet and water pump. There is no visible leak from under the sink. I checked the water pump and it is working and no leak around it. My best guess is that the leak is under the water pump. How do you access the hose/plumbing under the water pump? Thank you
                0 ·
What was the source of the leak? how did you fix it? Did you end up making an access panel like I did?
I suspect as these units age and need inevitable repairs, getting into that space is going to become a more popular topic.
Thank you so much!!!
