Jensen, again —Solved for Bluetooth option
deuce
deuce Member Posts: 47
edited October 2020 in Trailer & Towing
@AirBoss, @warbler_road, @JeffroNC
Well, the Jensen is acting up again. Now I don’t get a Bluetooth option when cycling thru the MODE button.
instead I get  “front auxiliary“ or “rear auxiliariy” and “HDMI ARC” In sequence
None of the turning Bluetooth off anon, using a paperclip to reset the Jensen, or holding in the pairing button works to correct the situation
I guess I’ll totally disconnect the Jensen and see what happens, but until then, does anyone have any new advice?
