Does anyone have the external start option on their Alde?  I can't find any explanation or instructions for it.  The manual doesn't even show it.  I thought I had turned off the Alde.  When I went to put something in the T@B, I noticed the Alde was still generating heat.  The only thing in an 'on' position was the 'external start' (I turned it off now).  I just want to know what it does and why I should have it on...
M@bel M@y, my 2017 T@B Outback Max S (silver w/black trim), towed by Maude Myrtle, my 2016 Jeep Rubicon Hardrock.
As I understand it, the external start allows the Alde to run without the control panel being on (DC power has to be on). You must set the parameters (temp/etc.) before turning the control panel power off.
When External Start is OFF, the Alde only runs when the control panel is on
When the control panel is OFF and External Start is ON:
EXT = an external contact closure (switch) turns the Alde on
120V = whenever 120V power is available the Alde turns on
2016 Max S, 2011 Volvo XC60
Btw, since the heat is up to 73° now (set at 75°) I thought I'd experiment. I turned off the ext and the heat is still on even with the control panel off it seems to be on when I turn the panel back on unlike this morning. Any idea why?
