T@B 400 only model with 2 beds?
Is the 400 model the only model ever made that has 2 beds? We have a 2010 TQ with the Queen bed, but our daughter is almost 13 and sleeping 3 is a bit tight. I also wonder if there is any kind of T@B wiki page that list all models current and past with sizes, layouts, etc?
Thanks,
Peter.
2010 T16-Q & 2013 Toyota Sienna Limited AWD.
    The T@B 400 is the only T@B model made in the US that has a second bed. The DM (Dutchman) and Thor T@B models didn’t have bathrooms, but had a closet in its place.
    You can research on this forum using the search function should you want to find out other info.
    Yes, the TaB400 sleeps two in the main rear bunk and one up front in the dinette, which makes into a nice bunk big enough for a small adult, I am 5’9”, 140 lbs, and sleep on this bunk quite nicely.
    Here is the standard floor plan:
    RV queen bunk in rear, dinette up front makes into a 37-inch at top and 28-inches at bottom, the table supports the filler cushion and the front edge sticks out for a night stand.
    cheere
