so many have discussed the waterproofness(or lack thereof) of the side tent. As a “retired” mountaineer/technical rock climber, I have always known of the importance of proper tent setup/maintenance. That said, as soon as I got mine, I seam sealed it. I like many have struggled with getting all the wrinkles out(key to a water tight tent). Last trip out, we really got a deluge and the tent performed “ok,” not great, but we were dry.  So I was staring at all the sags in the ceiling one rainy day, and it dawned on me: “what if I added a second hoop to the center.  I knew I had a bag full of old tent poles from tents I had thrashed over the years, so today I set the trailer & side tent up in the front yard and set to work, and voila, the center hoop has removed nearly 90% of the wrinkles an sags. I should note, that this hoop is in conjunction with the center spreader bar Paraque provides. Simple fix.  While I was at it, I scotch guarded the whole tent. It’s supposed to rain this weekend while we are out camping...bring it on!😈
PS try as I may, the back left corner ALWAYS wrinkles🤦🏻♂️
The silver rod is the supplied rod that extends from the t@b door to the tent door, the black rod is the new hoop. Velcro will be “Xed” at the bisection.
Tampa FL
you can use all of our collective “creativity” (if you wanna call it that!😬), and when you are at a neighborhood cocktail party tell everyone there it was your idea!😏
BRILLIANCE4U Aluminum Tent Poles Replacement, Fits Both Female and Male Ends, Lightweight Tent Pole Repair Kit, 7001 Series Aluminum Alloy T6 Heated 20 feet
Sturdy and had good instructions.
Tampa FL
