Refrigerator door gasket reinstall
trimtab
Member Posts: 237
2020 320-s, the
refrigerator door gasket
falls out of the groove on the door. I don't see any glue residue. Thinking I should glue it in.
What would you do. We have had our trailer since last May, purchased new.2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E
I would use 3M mounting tape to re-attach it.Rich2019 T@b 400
Try this:
https://tab-rv.vanillacommunity.com/discussion/5847/norcold-refrigerator-gasket-wont-stay-on-door
Coming off every time door is opened. Door and refer. Very clean.
Going to put a few spots of Gorrilla Clear Grip.2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E -
You have to press it in very carefully. Start at a corner, press it into the groove in the door....and do that around the entire door, especially in the corners. Mine hasn't popped out in a llooooong time. No glue.
Towed by 2014 Touareg TDi -
I did that for 3 days in Eastern Oregon. It still came out every time we opened the door.2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E
You could try a very small film of "Amazing Goop." You probably won't need it all the way around the gasket and you don't need a massive amount. Amazing goop can be found at Lowe's as well as many hardware stores.
Not sure where I saw it recommended, but I ended up using this 3M adhesive here. Did it this summer so I haven't used it a ton, but so far it's been working great.
https://amazon.com/gp/product/B000B8YE58/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
I used "Shoe Goo". Smell goes away after it cures and tube will last for years if kept in refrigerator. Good for many different permeant glue repair jobs.2016 T@B MaxS, 2018 Jeep Rubicon 4dr, Rural Scottsdale, Az.
owner of a 2020 320-s ( does the s mean it is faster? ) I used Loctite 480 with a few dabs spaced apart 6 inches all the way around. So far, the gasket has not moved.2020 320-S boondock, solar, 2020 Honda Ridgeline RTL-E
- 916 Introductions
- 72 Teardrop Groups & Links
