Refrigerator door gasket reinstall
trimtab
trimtab Posts: 237
2020 320-s, the
refrigerator door gasket
falls out of the groove on the door. I don't see any glue residue.  Thinking I should glue it in.
What would you do. We have had our trailer since last May, purchased new.
  • Horigan
    Horigan Posts: 900
    I would use 3M mounting tape to re-attach it.
    Rich
    2019 T@b 400
    Bellingham WA
  • Verna
    Verna Posts: 6,876
  • trimtab
    trimtab Posts: 237
    Coming off every time door is opened. Door and refer. Very clean.
    Going to put a few spots of Gorrilla Clear Grip.
    pthomas745 Posts: 4,645
    You have to press it in very carefully.  Start at a corner, press it into the groove in the door....and do that around the entire door, especially in the corners.  Mine hasn't popped out in a llooooong time.  No glue.
  • trimtab
    trimtab Posts: 237
    I did that for 3 days in Eastern Oregon. It still came out every time we opened the door.
  • You could try a very small film of "Amazing Goop."  You probably won't need it all the way around the gasket and you don't need a massive amount.  Amazing goop can be found at Lowe's as well as many hardware stores.
  • Not sure where I saw it recommended, but I ended up using this 3M adhesive here.  Did it this summer so I haven't used it a ton, but so far it's been working great.
    https://amazon.com/gp/product/B000B8YE58/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
  • Ron
    Ron Posts: 137
    I used "Shoe Goo".  Smell goes away after it cures and tube will last for years if kept in refrigerator.  Good for many different permeant glue repair jobs.
  • trimtab
    trimtab Posts: 237
    owner of a 2020 320-s  ( does the s mean it is faster? ) I used Loctite 480 with a few dabs spaced apart 6 inches all the way around. So far, the gasket has not moved.
