Homemade Awning for 2021 320 Boondock
BywaysNW
BywaysNW Member Posts: 71
edited October 2020 in Modifications & Upgrades
Tried it out at Oregon coast this weekend. No pooling or leaks after a rainy night.  Looks like a keeper.
  • PNWtabber
    PNWtabber Member Posts: 492
    That's pretty cool.  Thanks for sharing, @BywaysNW.
  • sptucker
    sptucker Member Posts: 42
    Love it.  I did not realize you could buy Keder "rope" -- great idea for a simple shade provider!
    2021 T@B 320S Boondock  |  2019 BMW X3 M40i
  • BywaysNW
    Amazon has it. Doesn't cost much.
  • PNWtabber
    I have a tent that has seen better days, I've been considering whether I could repurpose the rain fly.  This has given me food for thought!
  • BywaysNW
    I have had the same thought about a rain fly.  Don't see why not.
  • NotYourGuy
    NotYourGuy Member Posts: 16
    This is most excellent. Giving me an idea to "deconstruct" a family tent and put the keder rope in for a DIY attached annex room.
  • BywaysNW
    In case anyone is wondering, the Keder rope is on the 13-foot side of my tarp.
  • BywaysNW
    Leftover Keder rope with stapler, Speedystitcher (for the more patient and less lazy camper), and a rope hanger made from a short piece of Keder rope. Sailright and Keder websites - and Youtube, of course - have videos on sewing Keder rope.
    pthomas745 Administrator, Moderator Posts: 4,695
    How did your "speedy stitcher" work?  My only hangup about buying some Keder and setting up an awning to shade the "driver's" side of the trailer is my lack of sewing skills.
  • BywaysNW
    I did a foot or two on a piece of Keder rope. It's not difficult and there are some good videos. May try replacing staples when it gets dark and rainy and distanced.
  • Jackie_Dave
    Jackie_Dave Member Posts: 73
    We added a middle pole and lowered the two corner poles. It seems to work a little better. It keeps the shape more in line with the roofline of the tab.
    2018 T@B 320-S / 2007 Toyota Tundra
    Harpers Ferry, WV
  • ontheroad
    ontheroad Member Posts: 489
    There's an awning on the FB T@b Camping Trailers called the  "Boud Awning"...after my window awning projects..have 3 fabrics...might get ready to tackle it...although by that time I'll be waiting for the snow to melt!
    Former 2017 T@G Max XL
    2021 T@B Boondock CS-S
    2018 Nissan Pathfinder
    Ontario, Canada
  • Tampakayaker
    MarkAl said:
    Since I had access to a gear driven sewing machine and other items,
    That's what you need to successfully make an awning.
    The newer computerized all plastic sewing machines will choke on the material and keder rope, or strip the plastic gears.
    We found an old all metal Kenmore to add to my wife's stable of 8 or 9 various sewing, embroidery, and overlock machines.
    All it needed was oiling and a new drive belt.
    Tampa FL
  • PNWtabber
    We have a number of sailmakers in the Puget Sound area, I wonder if any of them would take a stab at making a PNW-appropriate awning for T@Bs.
  • Tampakayaker
    I bet they would welcome any work the way the economy is going.
    Tampa FL
  • BywaysNW
    We have outdoor gear repair shops that should be able to the job as well.
  • Verna
    Verna Member Posts: 6,876
    @Jeansor, I bought one of those canopies with hopes of attaching it to the Keder rail. Thanks, as yours is the first one I have seen attached. I am not a seamstress by any means but I will try. (Give me a scrollsaw and I could cut out a replica of the canopy!)
  • PNWtabber
    @Jeansor -- I like your version very much.
  • MarkAl
    MarkAl Member Posts: 510
    @Jeansor I agree it looks good. To figure the cut line did you back it into the trailer (somehow) and draw a line where the Keder rope would go? Do the ribs individually come out?
    Snohomish WA, 2024 3.6L Grand Cherokee
    managed by VE Smart Network
  • Jeansor
    Jeansor Member Posts: 28
    @MarkAl I just sewed onto the edge of the canopy.  No cutting or adjustments were made.  Here's a picture during set up - with my "helper"   ;)  The rope on the canopy is fed into the Keder rail, and then the cross poles are attached via clips on the top of the canopy.
    2013 Nissan Frontier
    2020 T@B 320 S Boondock Edge: Sm@lls
  • PNWtabber
    Keder question from a naïve newbie.  This is a photo of the rear passenger side of my trailer.  Please help me understand how this works.
    • I am assuming the silver metal at #1 is the Keder rail.
    • If you are attaching something like an awning, does the black insert (#2) get removed or ????
    • And, finally at #3, it looks like the previous owners had some damage here that has slightly deformed the rail, will that cause a problem in attaching anything?
  • Verna
    @PNWtabber, remove the rubber insert and, seriously, toss it. It has served its purpose.
    The wide spot is where you start inserting the Keder rail rope. It needs a wide spot or else you can’t insert the rope.
  • PNWtabber
    Thanks (again) @Verna.  I assumed it would be inserted at the end, oops.
  • Verna
    @PNWtabber, we all had to learn that. By the way, you may not have the same wide spot on the driver’s side. Pick up welding pliers at Harbor Freight and they will make a large enough spot to start the Keder rope.
  • PNWtabber
    @Verna do you have an awning on both sides?
    I purchased my trailer used from a private party, during covid isolation, so my questions are endless!!  ;)
  • Verna
    @PNWtabber, yes, I have two visors, but I have not used both of them at the same time.
  • PNWtabber
    @Verna are visors effective against rain or are they primarily for shade?
  • Verna
    Both, rain and shade. But, they are only 6’ from the T@B on out.
