T@B 400 Kitchen Faucet & Sink Upgrade
casadesaraymattcasadesaraymatt Member Posts: 20
edited November 2020 in Modifications & Upgrades
Made some upgrades to the sink and faucet of our 2019 T@b 400. Installed a new pull-out faucet on the counter top, and installed a new sink that is about 2” deeper and 1” larger diameter. The sink has a lot more usable space now. The factory sink and faucet were too awkward to use for washing large plates or pots/pans due to the limited depth under the faucet.
Overall an easy project, but it did require a few mods to make it work:
1) Cutting a larger hole in the countertop for the wider sink.
2) Modifying the drainpipe to allow for the additional depth of the sink.
3) Drilling a hole in the countertop for the faucet (after making sure there was enough clearance below).
4) Moving the upper hinge on the left-side cabinet door lower due to the new sink being wider at the bottom. (Did not anticipate this, but it actually worked out just fine.)
Faucet and sink purchased from Amazon. Total project cost was just under $250.00
