Light in outside storage not working
The light in the outdoor storage area doesn't work. Newly delivered 400. I've tried the switch of course. No breakers tripped. I haven't pulled every fuse yet as everything else seems to work. Suggestions?
Troy / 2020 Jeep Gladiator Rubicon / 2021 Tab 400 BD / Sarasota, FL
    Do the other DC inside lights work?  If not, you may have tripped the battery circuit breaker, which is inside the outdoor access storage area, back or side wall.
  • TRobTRob Member Posts: 54
    All of the other lights seem to be working. Even the one in the water management area.
    @TRob
    The switch on the light in my Nautilus compartment failed recently (took delivery June 1)...I contacted nucamp warranty and a new one will be delivered on Tuesday.
    So if you are willing and able to do the replacement yourself, just contact them.
    It sounds like you've got a dud light.
    Email them at warranty@nucamprv.com
    ChrisFix said:
    @TRob
    I think you're correct. I will contact them.
