Stove burner doesn’t fully light
Dona
Member Posts: 35
only half of the burner of one of our tab400 2burners lights up with flames. I’m thinking of unscrewing the burner to take a look, see if I notice an issue. I also don't know if that’s crazy, as I have no idea what I’m looking for. It came this way as a used camper. Has anyone experienced this and fixed it themselves? Thanks!
Dona & Ben / 2019 T@B 400, no solar, 2008 Tundra / Boise
I would unscrew the burner and check the propane jet as well as clean the slots in the burner head. These are small and a small amount of debris can impede the gas flow leading to no flame in a portion of the burner head. The propane jet needs a very thin wire to go into that opening.
Flame spreader needs cleaning, that’s my bet. Reaming the jet is not I’ll advised either.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback1 -
A tip cleaner is a handy and inexpensive tool that you should use for cleaning burners/jets/tips.....Lowes, Harbor Freight, Tractor Supply or any welding shop should have them. https://www.lowes.com/pd/Lincoln-Electric-Tip-Cleaner/3499658?cm_mmc=shp-_-c-_-prd-_-tol-_-google-_-pla-_-153-_-sospneu,air,rotaryshopequip-_-3499658-_-0&placeholder=null&gclid=EAIaIQobChMIyev696Hx7AIVCYizCh1NGQibEAQYASABEgK-wvD_BwE&gclsrc=aw.ds0
I reamed the jet with a tip cleaner and it now works!
$4 fix. Thanks for all of the useful suggestions! Dona & Ben / 2019 T@B 400, no solar, 2008 Tundra / Boise4
- 129 Dutchman and Vintage TaB Archives
- 30 "FOR SALE" - New/Used Trailers
