Better audio Streaming music/video inside or outside
We boondock 95% of the time and enjoy listening to music or watching movies from time to time. Setting up your system this way draws little or no battery power and still provides much improved sound quality. Very simple.
Needed:
Two Bluetooth speakers that can be linked together to provide left and right channels.
OontZ Angle 3 Ultra (3rd Gen) 5.0... https://www.amazon.com/dp/B073BVWRSP?ref=ppx_pop_mob_ap_share
Adapter:
Apple Lightning to Digital AV... https://www.amazon.com/dp/B009WHV3BM?ref=ppx_pop_mob_ap_share
Speaker cable: Syncwire 3.5mm Nylon Braided Aux Cable (3.3ft/1m,Hi-Fi Sound), Audio Auxiliary Input Adapter Male to Male AUX Cord for Headphones, Car, Home Stereos, Speaker, iPhone, iPad, iPod, Echo & More – Black https://www.amazon.com/dp/B01I0SI1SG/ref=cm_sw_r_cp_api_fabc_ANUQFb04E3GM5
HDMI cable:  AmazonBasics Flexible and Durable Premium HDMI Cable - Supports Ethernet, 3D, 4K HDR and ARC (4K@60Hz, 18Gbps) - 1 Foot, Black https://www.amazon.com/dp/B07KSP1SMS/ref=cm_sw_r_cp_api_fabc_cWUQFbGS9ZC8Y
Follow the pairing instructions that come with the speakers.
For streaming to the Jenson TV:
Turn off the Jenson receiver. All you need is the TV.
  1. Plug the Apple adapter into your phone/iPad.
  2. Plug the HDMI cable into the adapter.
  3. Plug the other end of the HDMI cable into the HDMI input on the back of the TV.
  4. Plug the speaker cable into the headphone jack on the back of  the TV
  5. Make sure the two Bluetooth speakers are paired with each other and your device per the product instructions.
  6. Plug the other end of the speaker cable into the controlling speaker input (the one speaker paired directly with your phone).
  7. The TV input source should be set to the HDMI input.
You should now have sound through the Bluetooth speakers with video on the Tv.  All volume control will be through your device.   As a result of the ceiling design inside, the acoustics can be great.  Try the speakers in different locations.  The goal is to have them placed so while listening you can’t pinpoint the exact location of the individual speakers.
