I am setting up a Tymate TPMS with High Temperature Alarm for my T@B 400 and can find no data for what my "High Temperature" setting should be. I have a basic understanding of Tire Pressure, and how that changes with air/road temps, driving, and just time. Not wanting to hijack other's threads regarding pressure, I would appreciate the helpful folks knowledge on the Temperature topic please. I understand these are just comments, and fully accept responsibility for my own decisions, informed or not.
Here's the (possibly?) relative info. I keep my trailer fully loaded ~ 3500 lbs. 2020 400 Boondock with the original Rainier Apex "C" rated ST tires. I do my best to keep the tire at 50psi 'cold'. I rarely drive above 60 mph, drive at sea-level, and have been as high as 10,910 ft, although not in the same day. I drive in all types of temperatures, paved roads and bumpy dirt roads. I've read other's threads regarding blowouts and am strenuously trying to avoid that. I tow with a Ram 1500 and based on what I'm hearing may not even notice a trailer blowout with this as a TV.
I don't want my alarm set too low, where it goes off when the tires aren't in danger, and of course don't want it set too high. I have looked on the tire, and it has a "Max" PSI, but no temperature info.
Anyone doing this, or have experience with tire temperature?
The idea is to see an anomaly and so you don't want it too high, so ambient temps need to be considered. I rarely see over 10f above ambient on my pickup or the Tab, so I set 20 over and figure if it alarms, there is an issue I should check on.
How do you determine 'pavement temps"? Hand (like I do for my dog walks)? Or do you have a thermometer of some type? This is all a learning experience for me.
Towed by 2019 Ram 1500 Rebel 5.7L Hemi 4x4 Crew Cab
Tire fires are likely due to bearing failures just like RR car wheel fires are due to journal failures. Fear not!
I really appreciate all of the information and viewpoints on here. It's a great bunch of folks with a lot of knowledge.
Happy Thanksgiving.
Regarding the semi-truck tire bits, from my understanding, though I might be wrong, the shredded tires are retreads coming apart. Cheaper to replace one of those big truck tires with a retread. And why not - they've got redundancy on the dual tires! Just more data for you to chew on...
I had one blow right next to my open driver window one day, as he was passing me on the interstate. Scared the $#!π our of me! I was very glad it didn't blow a few seconds later - most of the shrapnel flew out behind me, rather than in my face.
I hate to imagine being on a bike in that situation...
Drove from Willis Texas to Junction Texas, mostly backroads. Stayed at 60 mph, daytime temp varied during my drive from a low of 64dF to a high of 74dF. Trailer tires started out at 50psi, and 71dF. Sun was up when I got the readings but didn’t appear to make a difference.
The highest temp my trailer tires saw was 85dF and their highest psi was 54.
The truck tires got up to a high of 60 psi (from starting at 55 psi).
It sounds like your system is checking temp at the valve (of internal air?). All of my experience with tire temps is at the tread using a pyrometer. I could give you all sorts of suggestions/analysis if you wanted to talk tread temps, but fear they'd be useless here...
2019 320 Boondock Edge - Sold Jan 2022
When time permits, I would definitely appreciate your data! Knowledge is power.
Not all tire failures on big trucks are recaps, the guy that replaced me on the truck I used to drive lost a brand new virgin steer tire, he safely got truck stopped on shoulder, but it did go off like a bomb with just a few thousand miles on it. It might of given early warning with a TPMS system.
North Texas - Retired Air Force
Trips - 46 Mileage - 58,461
