While on battery (2X6-volt AGMs and no solar and no shore power) power I measured voltage at the maxxair cabin fan leads at 12.6 volts. I removed the 7.5 amp fuse in the under-seat fuse panel to do some work on the fan and also removed the fan from the circuit. With the both out of the circuit I measured the voltage across the power leads at 6 volts both to neutral and ground from the hot wire. Why would I have a normal 12.7 volts with the fuse in and 6 volts with the fuse removed.
                2019 T@B400
Southern California
Full-timer since 2019
0 ·
2019 T@B400 Rogue
2012 VW Touareg 3.0 TDI
Southern California
Southern California
2019 T@B400 Rogue
Southern California
Southern California
Neutral is usually referring to AC wiring, vs DC which has two conductors, positive or "hot", and negative (which is sometimes ground). In an AC circuit you'll have three wires which are hot, neutral, and ground - ground and neutral not being the same.
Southern California
