Hey, I looked through the forums quite a bit and found some good resources on installing the roof rack, but I found conflicting information on the spacing of the aluminum frame members.
On this thread:
https://tab-rv.vanillacommunity.com/discussion/4154/diy-roof-rack-on-t-b-similar-to-outback and on this manual from nuCmp:
https://nucamprv.freshdesk.com/helpdesk/attachments/2043072192632, the roof rack needs to be attached 10" from the center of the bottom trim and then every 8" on up for 10 total attachments or 72":
However, I was looking at the structural drawings nuCamp also provides here:
https://nucamprv.freshdesk.com/helpdesk/attachments/2043071800901, which shows uneven spacing on the roof frame - 8.5" / 10.5" / 12" / 10":
This has made me very hesitant to drill into the roof without actually knowing where the frame cross bars are at.
I've tried stud finders without any luck. I've looked for condensation on early mornings without luck.
Was there a model year that they switched from one roof frame to the other or any way to definitively know which spacing I would have on my Tab?
2019 320 Boondock Edge - Sold Jan 2022
Edit: I noticed that the drawings you referenced are dated 8/8/2019. I imagine they are for the 2020 model year (My 2019 model was built in July of 2018).
I was also looking at the dates, and didn't understand the discrepancy when the roof rack installation guide was last modified 12/17/19 and the structural drawing was dated 8/8/2019, but it makes sense to have structural drawings for the next model year and aftermarket guide for prior model years.
Adventures: 58 Nights: 405 Towing Miles 50,180
Direct link to structural drawings here: https://nucamprv.freshdesk.com/support/solutions/articles/44001867242-tab-320-structural-documents
For some reason I can only view those pages when using the link you provided.
On my own, keep getting not Authorized to Access message.
Kind-of-like it's a dealer only area. Internet Software is getting too complex for me
Note factory black caulk on unused holes. Hmmm????
10 1/4" from center of bottom trim piece to center of lowest bolt:
Hope this helps. Good luck!!!
North Carolina
2015 T@b Max Q
Yes, I could not find the Yakima tracks nor the long Yakima cross bars in stock. My original plan was to use rhino rack tracks (the tracks work identically and are very similar in design), yakima landing pads and towers, and then just use 3/4" sch 40 black iron or galvanized pipe in lieu of the cross bars (same outer diameter).
Instead of yakima landing pads, towers, and pipe cross bars, I am going to try mounting this rack on the rhino rack tracks which I hope will be a more polished look and is quite a bit less expensive than the yakima components: https://www.etrailer.com/Ladder-Racks/SportRack/SR1020.html?
Even with recent model year roof racks appearing to have the 8-inch bolt spacing it couldn't hurt to contact NuCamp Support and confirm all is well/correct.
Very cool, I think that makes it pretty definitive that we need 8 - 8 1/4" centers for the roof rack connections. where did you find the factory tour photos?
It looks like all the yakima components are now available:
Tracks:https://www.etrailer.com/Roof-Rack/Yakima/Y01135.html
Landing Pads: https://www.etrailer.com/Roof-Rack/Yakima/Y00246.html
Towers: https://www.etrailer.com/Roof-Rack/Yakima/Y00148.html
Cross Bars: https://www.etrailer.com/Roof-Rack/Yakima/Y00411.html
I also bought very long tracks based on nucamps installation guide showing 10 connections at 8” spacing, so I just continued to run it up all the way to the crossbar supporting the ceiling fan.
Parts:
Rhino Rack Tracks: https://www.etrailer.com/Roof-Rack/Rhino-Rack/RRRTV208.html
Sport Rack Roof Rack: https://www.etrailer.com/Ladder-Racks/SportRack/SR1020.html
Notes:
Marking out the right rail:
Right rail installed, marking out the left rail:
Both installed and test fitting the roof rack:
(pardon the missing plastic fitting on the right track - I need to reinstall)
(@kheyborne - if you place an “@“ before a member’s name, they will receive a notification.)
Yes, the cross pieces are tubing, from what I could see / feel from the holes I drilled, they matched what is shown in this picture, which is rectangular aluminum tubing:
https://us.v-cdn.net/5021717/uploads/editor/8k/b1d4tc36ubw8.png
If you go the rhino rack route for the tracks, the tracks will come with screws or rivets to attach, depending on the version.
I thought about screws (which is what is stated in the installation guide), but was hesitant because I didn't want to risk a steel screw stripping out the aluminum structure and didn't want to worry about screws working their way loose. I instead went with rhino rack tracks that come with rivet mounts (this version: https://www.etrailer.com/Roof-Rack/Rhino-Rack/RRRTV208.html)
