I have seen multiple mentions, here and elsewhere, that one is likely to blow a little glass 3.15A fuse or two on the Alde when disconnecting or sometimes connecting shore power to the camper.
Why?
Firm advice indicates one should always turn off the Alde before connecting/disconnecting shore power.
Some reports say it is the ground fuse, so running a separate ground from the Alde to the battery's negative post solves this problem. Some say both fuses blow, some say they never have had the problem.
My 2019 400 BDL camper (used) came with two spare fuses in a bag on top of the Alde connection box, so I am assuming that is stock configuration and they never blew. Or, the previous owner had the problem and left replacements handy.
I have on numerous occasions had the power fail and my EMS disconnected the shore power until it was again stable. I have also, either by fault or before I knew this was a problem, disconnected shore power with the Alde on, but most likely not heating.
As an electrical engineer, I find these circumstances difficult to understand. Why would an obviously well designed piece of equipment be likely to blow a fuse on its DC ground line when AC power is interrupted? Is this due to a design flaw, improper installation, a problem with associated equipment (the converter), faulty wiring in the camper, or perhaps the way some folks connect the shore power cord?
Could they be unplugging the shore power cord in such a way that the neutral line is broken before the hot and ground?
Does it only happen when the shore power breaker is not turned off before unplugging the cord?
Does it only happen when the shore power cord is first disconnected at the pedestal?
Proper disconnect technique is to first turn off the breaker on the pedestal, then disconnect the twist-lock connector at the camper, then unplug the cord from the pedestal. Proper connection sequence is breaker off, cord to camper, cord to pedestal, breaker on.
Does it only happen when the Battery Disconnect switch is in the Off position?
I would appreciate reports from anyone having direct experience with this problem, especially if they can recall the sequence used, whether or not the 1kw or 2 kw heaters were operating, and the status of the battery disconnect switch.
I don't want to awaken to a freezing cold cabin and have to take the bed apart to replace a fuse just because there was a power glitch.
2019 T@B 400 Boondock Lite, BMW X3
0 ·
The original Alde Model 3010 had two 3.15A fuses on the main PCB. The Ground side fuse would blow most often if shore power was switched off while Adle was on however the ground side fuse also blew in non-shore-power switching situations. Adle / NuCamp never provided a technical description of why (as far as I know). Adle / NuCamp did provide the grounding work around, extra ground wire to Adle, that solved most of the ground side fuse failures . . . however having Adle on when shore power was switched off could still blow fuse, just not as often.
The Alde Model 3020 which has been installed since December-2017'ish does not have the ground side fuse on the main PCB. Model 3020 owners in general have not been having 3.15A fuse failures.
Expect your two fuses taped to Alde are the original factory spares. My March-2018 build T@B with a Model 3020 also came with two shares . . . and they are still waiting to be needed . . .
Hope that helps.
As a rule, I like to use very stout busses for power and grounds, so I think your #8 ground-battery cable is good practice. When signals are ground referenced, any change in ground potential due to high currents in the ground buss can disrupt the signal, especially high frequency spikes.
