Hitch drop for 3rd gen Toyota Tacoma
chuty
Member Posts: 17
I got a 2020 tacoma to pulled our 2019 320s boondock edge with a 2'' drop hitch. the tounge of the trailer look slightly tilt down. I can't find any 1'' drop or less. any suggestion is greatly appreciated.
Thanks.
Thanks.
IMHO if you flip your hitch It will put you where you need to be.
@justdoit70 Didn't even think of doing that I sure will flip it and see how it work out
Thanks a lot -
I believe mine has a two inch drop also. I added a ball that was one inch taller from Amazon. I now tow level. I have a 2015 T@B 320. I also purchased a longer hitch which allows me to open the tailgate while hooked up. I believe I got it from ETrailer.2015 Little Guy T@B Outback
2017 Toyota Tacoma Offroad
Bishop, CA -
@chpiv I will check amazon to see if I can get the taller one like you suggest
Thanks -
@chuty, I use a Toyota receiver on my 2018 4Runner. Measuring drop can be inconsistent but its approximately a 1" to 1-1/4" drop and is a perfect match with my 2021 320 Boondock. Its Toyota p/n P1228-89445. Possibly another option to consider. Its a very heavy duty receiver as well.
2021 T@B 320S Boondock - 2018 Toyota 4Runner -
@mntrails if it's 1'' or 11/4'' drop it may work perfect I'll check it out
Thank you -
I went out and measured - bottom of the flat stock is even with the bottom of the inside of the receiver tube. The flat stock is 3/4". The top of the flat stock is 1-1/4" to the top of the inside of the receiver tube. I'd call that 1-1/4" drop. Plus, its a nice short receiver so less moment arm and thus doesn't add more leverage to the trailer tongue weight. I did see one on amazon. I hope the measurements help.2021 T@B 320S Boondock - 2018 Toyota 4Runner
I just found one at a toyota dealer near me part # PT228-89445
will go over and see if it would work . Thanks again -
Just talk to the dealer and they said this one does not work with my truck. oh well keep on trying.
found curt hitch ball 40033 1'' rise on amazon and trailer sit even now
Thanks @chpiv and everyone here for the help.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
