Hi I cannot figure out how to use the TV. What can you access with the HDMI cable that's already connected? I tried disconnecting the one thats installed with an HDMI linked to my PC and got a picture but no audio.
 Any suggestions?
Also what recommendations are there for the best antennae arrangement. Thank you.
                0 ·
Oh, and reconnect the HDMI that was installed. It's prewired to the back of the Jensen so it receives the audio signal when you're watching TV, and outputs audio/visual when playing a DVD.
Make sure you have the correct Zone selected for the speakers. The Jensen has three different zones (A, B, and C). In my rig, they've tied all zones to Zone A. Which make sense because the rig is really not big enough to warrant 3 zones. Obviously make sure the volume is turned up sufficiently. And BTW, once you're up and running if you want to hear the TV better when dining at your "table by the window", just use the "Fade" control to Front speakers, and when you're snuggled up under the Stargazer window, Fade it to the Rear speakers.
Turn on the Jensen and select "HDMI ARC", then turn on the TV and get your signal (cable, over the air). It may take a few seconds to connect but you should get audio thru the speakers.
Do you get audio when pairing to Bluetooth, AM, FM, etc?
FYI, that small hole under the large control knob can be your friend. Use a paperclip and push it into the hole when the Jensen is on. You'll hear a "pop" but it can be helpful it "rebooting" the unit.
San Diego, CA
www.airbossone.com
2020 Audi SQ5
2020 F150 3.5 ecoboost
Columbus, OH
Thanks for the update on 2021. Few changes from 2020. Curious what the thinking was from Jensen...now 3 cables. An HDMI and 2 RCA's(kinda old school) instead of just one to watch TV, if I understood correctly? Why take up an AUX channel when the HDMI can carry the load?
That's why this place is so helpful. nuCamp and their suppliers keeps changing and updating (which is 95% a good thing) so knowing which model and build date are important.
Hopefully @JerseyGirl13 has resolved the issue permanently.
Cheers,
San Diego, CA
www.airbossone.com
