Kuma Outdoor Gear Propane Fire Pit
CharlieRN
Member Posts: 438
Has anyone had any experience with the Kuma Outdoor Gear 19" Blaze Bowl?
A quick search on the forum didn't turn anything up on this specific unit but it gets good reviews on other sites.
My little Red Campfire is about 8 years old and still going strong. Propane campfires are a great idea. I carry a 10 lb propane cylinder just for it and it works well.As summer fire season approaches, you will see more discussions as these can be used in all but the worse fire bans.Verna, Columbus, IN
I feel like I read something somewhere about it making a mess unless you buy the bag to carry it because of the holes in the sides.CharlieRN said:Has anyone had any experience with the Kuma Outdoor Gear 19" Blaze Bowl?A quick search on the forum didn't turn anything up on this specific unit but it gets good reviews on other sites.San Francisco Bay Area
I will echo @Verna comments.
Little Red is a perfect fit. Small, lightweight, throws good heat.
Don't leave home without it...2020 T@B 400 "OTTO" (build date 08/19)
San Diego, CA
www.airbossone.com
https://fineartamerica.com/profiles/owen-ashurst/shop -
Verna, AirBoss do you have any comments about the Little red being loud as some reviews mention?
@runaway30, no, mine is not loud. I did buy a larger one, a different brand, a couple of years ago and gave it away because it was loud, smelled of propane and used propane quickly. The Little Red is quiet, conservative on propane use and there is no odor.Verna, Columbus, IN
Ditto here. Efficient, quiet, and lightweight. Really don't have anything negative to say about it.2020 T@B 400 "OTTO" (build date 08/19)
San Diego, CA
www.airbossone.com
Has anyone adapted the Little Red to run from the propane outlet on the rear of the T@B 400? We tried with my daughter's 400 and couldn't get enough pressure out of the line.2014 T@b S Max AKA T@dpole
This thread explains the issue of the presence of the second regulator in the fire pit and grills while using the low pressure propane port.https://www.gopetfriendly.com/blog/hooking-propane-fire-pit-rv-quick-connect/
- 953 Air Conditioning & Refrigeration
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
