I installed Sumosprings myself using a torque wrench and basically never thought much about them again. They are only compressed when the trailer is pushing down on them, and without the trailer I don't think of them. I got the black, 1,000-lb. ones.KiwiYYC said:something like the Sumosprings. What are the advantages/disadvantages of those options for preventing sag in the Taco?
Denny16 said:@ChanW I do not have all the tech bits, but Look at the manufacturer’s towing specifications on most trucks, the auto tranny is higher rated. An auto transmission uses a torque converter which delivers more power to the axle/wheels than a clutch disk can in a manual transmission.
I’ve had Airlifts on four different trucks, three being Tacoma’s. They worked well. There(inflated) when you need them, not (deflated) when you don’t. My newest 2019 Tacoma I went with a 1.5 AAL- (add a leaf) to try something different. Though a 1.5 lift, it only raised my rear about a half an inch unloaded. This is because I have a ARE high rise topper, rubber bedmat and a tool box in the bed. The ride is slightly stiffer than stock. With the 320 Boondock hitched and loaded the truck rear did not drop. Early summer for a family vacation I rented a Coachman Nano 187 from RvShare. About 33-3700 lbs rolling. This did drop the rear an inch or two. But pulled fine with no WDH or sway control.KiwiYYC said:Really appreciate all of these comments! Seems that the Tacoma will work but we’ll need to be careful with packing, especially given the payload of our Taco is only 945 lbs. One thing that I’m not that clear on is whether we would be better off with helper springs or with something like the Sumosprings. What are the advantages/disadvantages of those options for preventing sag in the Taco?
The Tacoma 6 cylinder motors deliver maximum horsepower beginning at 6,000 RPM. To many folks used to running between 3,500 and 4,500 RPM's pushing it over 6,000 seems may seem abusive but that is what the motor is designed for.TAOSMAC said:On steep climbs the Tacoma sounds like it’s screaming and overworking.
