Alde T@B 400 (2019) not circulating heat
2»
    @lisadbricker the owner @Davids has not been active on the forum since September 2020.
    Hi @Davids. We are having a similar issue with our heat not working beyond the Alde storage compartment in the back of our T@B 400. In a different thread we’ve been troubleshooting with helpful advice from others, but nothing has worked. I’m wondering if you solved your issue, and if so, what worked for you?
    I sent you a personal message to see if I can help you out.  Would like more information on your issue and what you have done to remedy the issue...  Thanks
