Screw Drivers
SolomonsIsland
SolomonsIsland Member Posts: 6
edited June 2015 in Trailer & Towing
Hello from Maryland,
What type of screw drivers do I need for the 2015 MAX S? Nothing I have seems to fit and I don't want to strip anything.
Thanks!
  • Verna
    Verna Member Posts: 6,876
    A #2 and a #3 square drive. #2 is the most frequently used. I use the bits in my cordless drill.
  • SolomonsIsland
    Thank you so much!
  • Verna
    You're welcome.
  • mawebb
    mawebb Member Posts: 257
    As a bit of trivia, square headed screws are a Canadian invention. They were developed by the P. L. Robertson Company in 1908. The U.S. counterpart is the Torx, which was designed for use by automated assembly systems. The patent rights to the Robertson design have been expired since 1964 so they are more prevalent than they were a number of years ago.
  • Ratkity
    Ratkity Member Posts: 3,770
    edited August 2015
  • Verna
    I love square drive screws in my woodworking and home repairs. They're harder to strip the heads than Phillips and pan head. The pocket screws are square drive are so much easier to drive in than other types. Just a lot easier. Maybe I should get a couple of screw drivers instead of relying on my cordless drill driver and bits, but I do have a couple of screwdrivers that have exchangeable bits.
  • Michigan_Mike
    I know I've replaced a few with Phillip's head style screws.    =)
  • LARK
    LARK Member Posts: 146
    Verna- you can use small flat head screwdrivers if your in a pinch. They fit in catty-cornered sufficient enough to turn the screw.
    M@rk and Donn@ : 2015 T@B S Max, Silver/Black, 2008 Toyota Beef Taco DC
  • ChanW
    ChanW Member Posts: 3,171
    edited July 2015
    And then there're the durn star-headed screws (I thought those were what they called torx screws...)
    I'd just got used to the square ones, which I actually like for being hard to strip, and then them danged star-headed screws came along.
    Chan - near Buffalo NY
    2014 S Maxx (ie: "320")
  • Nomad
    Nomad Member Posts: 7,209
    I just went to Lowes and bought a screwdriver/head set with every type of head known to mankind. 48 tips/heads as I recall for about $30-35 bucks.
  • ChanW
    edited July 2015
    48, eh? That gives me hope...
  • Nomad
    They had sets of 24, 36 & 48. Every type including stars
