Greetings. I have ordered a 2021 Tab 320 S Boondock and should be receiving it through my dealer in January.
I'd like to store it in my garage. This model is listed at a height of 96 inches (8 feet). Obviously that is right at the height of my garage opening.
If I lower the front hitch to its lowest point before pushing the 320 in, how much does that lower the roof height? Seems like it would drop that height by at least an inch or two.
Anyone have experience doing this? I've seen many older posts about other methods (removing rims, letting air out, etc) - but those seemed more focused on getting it in a 7' garage opening.
1. Do you ever leave the tires deflated in the garage? Or do you always inflate them back to normal after pushing it in? I'm guessing it's not good to leave them deflated, especially if you're going in and out of it.
2. Do any of you recommend an air pump? I would mainly use it for this purpose...but possibly for winterizing as well. I see many fairly inexpensive ones on Amazon, just curious if someone has one in particular that they really like
I hope you are able to finagle it to where you keep your unit on-site, that's where they should be. It's a luxury I don't have.
https://www.amazon.com/VIAIR-30033-300P-Portable-Compressor/dp/B000X90YUO
The 300P has gone up in price, I paid @ $60 from an amazon warehouse deal about 5 years ago.
CRAFTSMAN 6-Gallon Single Stage Portable Electric Pancake Air Compressor in the Air Compressors department at Lowes.com
For the deflation, I got this quick air-down set up, which also saves a lot of time:
Amazon.com: Boulder Tools All New Heavy Duty Rapid Tire Deflator Kit with Valve Caps, Valve Cores & 4-in-1 Tire Valve Tool: Automotive
I thought about different wheels, but as a permanant solution instead of off and on. I am not sure, but for a 2 inch drop in the tire size, wouldn't only 1 inch of it be below the axle, so the trailer height would only go down by 1 inch?
Different tire sizes should be explored on the 13” rim as well. Such as a very low profile tire.
The trailer has stock battery and propane on the tongue but all the tanks are dry and there's no gear in the trailer. The highest part of the trailer (that new plastic molding along either side) taped in at 95.5". The new molding appears to be just slightly higher than the Fantastic Fan vent. Any modification to the stock vent and it would not fit.
2017 F-150
Coeur d'Alene, Idaho
