fuses for Alde
Tundra57
Member Posts: 640
I have a Tab 400, 2019 with Alde heating system. I have heard talk on this forum about fuse problems, which thanfully I have never needed. However, I would like to have spares just in case.
Being as the system is made in Sweden, fuses would most likely be 5mm x 20mm.
But what values are suggested and are they fast or slow blow?
Also they can be HRC (all white except for the ends) or glass depending on the voltage rating.
So anyone can tell me what I need to keep?
“Fuses for Newbies” has the fuse valuesVerna, Columbus, IN
Here is the Fuses for Newbies. Use slo blow on the Alde.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
For the 2019 400 BDL the "unofficial" guide has a comprehensive fuse and electrical section starting on page 103 in the pdf attached. The rest is pretty good as well. File is pretty large so sorry if this this too big to post there may be another link on the forum2019 T@B400 Boondock Lite "Todd"2016 Toyota Tundra 5.7 Crew Cab
The "Alde Fuse Blowing Problem" really seems to disappear after a certain model year (2018? 19?). I think Alde and NuCamp figured it out, ran a better ground, etc. It just doesn't seem to happen as often. As I understand it, the newer models only have one fuse.
- 916 Introductions
- 72 Teardrop Groups & Links
