Another newbie, so excited to pick up my Tab . I have my hitch and brake controller (7 pin) installed. I still need a sway bar attached to the Tab, will have that done at the dealer before I pick it up. Does it matter which side the sway bar is on? I am thinking the left side would work best for me , not sure I will remember to unhook it if it’s on the right side. What I really want to know is how does the Highlander perform as a TV? I have towed a small Aliner before, but not with this vehicle. Thank you so much for our awesome forum, I have learned so much already.
0 ·
Doesn't really matter which side for the anti sway bar but practically speaking the passenger side is safer as you are on the opposite side of traffic in the event you have to work with it on the side of the road or in a campground.
Depending on length of travel in the bar and considering the much preferred method of backing is to angle back on driver side instead of passenger (blind) side whenever possible, you may stand less chance of damaging the bar as it will be extending instead of compressing.
San Diego, CA
www.airbossone.com
And yep...sticky notes are alive and well. Actually some folks I've seen place a label (remember the old label makers?) next to the gear indicator on their TV that says "Bar!" You look down (or into your instrument panel) to make sure you're in "R" and there it is...
You'll do great! And if your forget and jack-knife it...you'll only forget once! ;-)
San Diego, CA
www.airbossone.com
We don't use a sway bar and haven't found a need for it, though this is likely partially due to the high tongue load our Tab 400 (2019).
We're about to install some Supersprings (link below) to help address the rear sag since Highlanders can't accommodate airbags.
https://www.amazon.com/gp/product/B009JC42PE/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
