Mystery Roof Leak
JeffroNC
Member Posts: 366
We have water coming in at the front edge of the roof vent while it is closed. It has gotten into the ceiling. I got up on the roof and while the caulk is a couple years old, I could find no defects. I cleaned the area and added some leak seal caulk I got from Ace. I’m going to water test it in a little while.
I can’t figure out where it is coming in. Any ideas? There was a bubble at the area I circled but it didn’t go through.
Oh yeah, I had an appointment at NuCamp to get all the caulking checked but I couldn’t make it as my tow vehicle was out of commission. 🙄
Jeff & Amy
Jeff & Amy
Now in Manistee, MI
Any cracks, or loose seal on the vent itself?2006 RAM 1500 4 door, 2016 T@B 320 MAX S
Tampa FL0 -
@Tampakayaker it looked like the photo all the way around. I couldn't see anything that I thought could leak. Anyway, I slathered it with Lexel. It was recommended by the guy at Ace. We were leaving the next day and I needed to do something. To my surprise, it worked as it poured rain the next night.
Give me an electrical problem any day over this kind of stuff.
Jeff & AmyNow in Manistee, MI0 -
I once had a car that was getting wet in the trunk. Nothing visible from outside, finally I got in trunk and had my wife spray with a hose, turns out there was a pinhole leak in a body seam, very small let a lot of water in and a dap of caulk in correct place solved issue. Point is sometimes it is a small hole and difficult to find.2019 T@B 400 Boondock Lite0
In the words of Nanna Rosannadanna: It goes to show its always something..
:-)2019 T@B 400 BDL 2017 F150 3.5L Ecoboost
Jeff & AmyNow in Manistee, MI1 -
I would suggest using a product designed specifically for RV roofs from an RV supply store.Like
Dicor 501LSW-1 Self-Leveling Lap- Hash T@B Fun
2 -
@Dalehelman I will get some of that. Thanks.2019 T@B 400 BDL 2017 F150 3.5L Ecoboost
And from the unofficial guide this was recommended. I have not had the occasion to try it yet but it seems like it should work in your situation.FREE Delivery Fri, Mar 5
Just don’t use a silicone based product. It won’t last and it can never be completely removed, and nothing else will stick to it.
- Hash T@B Fun
- 427 Service/Maintenance & Recall Notices
