Cover for side air conditioning vent on T@B 400
Om3Om3 Member Posts: 72
edited December 2021 in Tips & Tricks
Recently, we noticed a photo of a T@B 400 with a cover over the air conditioning side vent. We have thought that perhaps,
a cover would prevent wasps, hornets, etc from making "home" behind the screen. Just wondering if anyone has experienced
this problem with their T@B...and how did you remedy it?
    edited February 2018
    Elsie in Parts at nüCamp will have the A/C cover.
    I normally take my cover off on my T@B 320 A/C unit as soon as it starts getting warm, so it’s not a solution to keep out stinging critters. But, there is a fine screen between the outside louvers and the A/C unit, so you should not have to worry about those stinging critters nesting in the A/C units.
    May have been our 400 with the cover installed that you saw.  I keep it on when it is cooler weather, prevents cold air from filtering in.  Also keep it on when towing to prevent outside contaminants from getting inside. Stays on while the 400 is in our shop with just the upper snaps fastened.  A pretty simple installation and we used one on our 320 also.
  • TabneroTabnero Member Posts: 247
    it keeps the rain out when driving. Mine is made of an old plastic box lid and velcrow. You know the build material of champions, giggle
    Yep, Velcro & duct tape....helps keep America "stickin' around! :rofl:
  • Om3Om3 Member Posts: 72
    Thank you so much for these responses!!!!  Very helpful, indeed :)
  • GrandmasKidGrandmasKid Member Posts: 163
    edited March 2021
    I'm a new 400 owner and I got a cover for the A/C vent that came with it. It snaps on easily and matches the side wall color but I don't see how it would keep buds out as it is loose enough that bugs can easily get in. I wonder if this is something worth doing something about. Should I travel with it attached or might it fly off?  Just when should I put it on? Any advice or thoughts are appreciated. Thanks.
    I only put my on for winter storage, it may keep something out, but not much. When driving it seems like it would tear itself up pretty quick, so after one short trip I took it off. I don't worry about rain while driving, it should be pretty sealed from the inside, after all the bottom tray fills up and spills over the side when using the AC, plus any rain should pretty much slip stream right past the vent when towing in rain.
    edited March 2021
    As far as insects go, only Very small spider creatures are likely to get past the fine screen on the outside AC vent.  So no need to worry about bees, wasps, etc setting up house in the AC vent, not enough room on the out side the screen, and they are not getting past the screen.
    The cover is for dust/dirt and reduce air drafts in winter.
    FWIW, we drove with ours attached for 24,000 miles last year and it was still there. LOL
    Jeff & Amy
    Now in Manistee, MI
  • Melanietab400Melanietab400 Member Posts: 10
    Has anyone had issues towing in the rain with road spray getting in the trailer? Are you supposed to cover the cool at while towing in the rain?
  • ColoradoSunColoradoSun Member Posts: 135
    Melanietab400 The factory supplied cover is intended for storage only not when being transported. However I have heard that some people leave on while towing. I haven't had a problem with road spray when towing with the cover off but I have not towed in the rain much.
    SW Colorado
    I was cautioned by our dealer to remove the CoolCat cover before towing, as it can be pulled off by the wind.  Any rain entering the rear grill will just drain back out, so not an issue.
  • BinghiBinghi Member Posts: 368
    I left the cover on once while driving. Noticed something awry in my side mirror; it was the cover catching wind and looking like it was going to fly off. Pulled over and took it off to avoid possibly losing it. I don’t recommend leaving it on while on the road.
