2021 tab 320 S Boondock Victron solar settings
RetiredguyRetiredguy Member Posts: 25
Newbie question re solar.  We have a 2021 tab 320 s boondock.  We have two Interstate Marine, Deep Cycle, SRM 12V batteries hooked up in parallel. In our Victron app our battery setting is set at factory default: (Gel Victron Deep discharge  (2)).
Our battery is currently at 14.49 volts and the current of the battery is at 4.3 amps. The state is now in absorption.
Float should be at 13.8 volts and absorption is now at 14.5V. according to the settings, my battery shoukd have triggered to the float mode at a absorption voltage of 14.4V.
Are my settings correct with this setup?  I worried that I might be overcharging my battery at this higher voltage.
