My simple solution to block Jensen cube light at night
Chopin
Member Posts: 47
A piece of aluminum foil. Works perfectly!
Photo too large and deleted. Moderator
https://tab-rv.vanillacommunity.com/discussion/47/what-size-should-my-posted-forum-photos-be#latest
If you tap the power button (vs holding it down) it will turn the leds/display off.Ironically you can’t do this when the unit itself IS off.My next mod when I get back from this trip is to install an external power switch to be able to shut it completely off, zero power, when boondocking.1
Thank you!!! I had tried to figure this out
@Chopin
You can turn the display completely off in settings. Set the Dimming to the lowest setting, which is completely off, then simply press the power button and the screen will dim, in this case to black. Press the power button again, and it comes back on.
No foil needed!2025 T@B 400 Boondock Black Canyon with 400Ah Battle Born and Victron Multiplus 3000
2025 Honda Ridgeline Black Edition with Redarc Trailer Brake Controller2
- 424 Service/Maintenance & Recall Notices
